SRS W213 memory erase
Hi, how to erase errors from airbag controller? There is 20+ errors, all errors labeled (STORED) and I cant erase them? I tried with Xentry and Vediamo, with no success. Is there is some function to call and then erase or etc?
On the lighter of any activated bag, set a 2.2 ohm resistor, clear the faults, and monitor whether the number of faults has decreased by 1. If it is, change the damaged element and clear the faults. If the number of faults does not diminish, you must remove the airbag controller, open it and see what memory it is in, read and delete the crash data.
Can I do it in software layer with no intervention of hardware tweaking like connecting resistors, because the airbags are ok, I never changed them. The problem was in wires and connectors. And the fault's are labaled as STORED
Any of those stored errors are internal errors?
Feel Free to Thank me if I helped you. Everyone can enjoy some gratitude. Tup
79 Passionate about Mercedes Benz. Still learning everyday.
Thanks given by: Rocinante , autofault
#5
No, there is no internal errors in fault memory list. Do I need to flash SRS controller? I see that there is STM chip, but the model W213 is pretty new, so how do I flash it?
FN_hard_reset and then delete errors
Thanks given by: Rocinante , glstefanov
try :srs/adaptation/function/login/release
need use special function password generator
Skype: live:ht_106
I offering install software in request via teamviewer, current, xentry 09/2018 new full active.I can one click ,activated full xentry any version.
tirex2k:
where can I get "FN_hard_reset" function? I can't see in vediamo functions list?
Sadly but I don't have special function password generator, can I do it in another way?
Thanks!
(09-20-2018, 02:02 AM)demonq Wrote: tirex2k:
Thanks!
use vediamo/monaco
  w212 srs not initialized aLadie 2 88 7 hours ago
Last Post: aLadie
Mercedes Benz Memory seats activation in one press demonq 4 530 09-16-2018, 07:36 AM
Last Post: demonq
  Random: How sensitive SRS modules can be Karu 22 1,400 09-13-2018, 12:50 AM
Last Post: DiagnosticSolutions
Mercedes Benz Need SRS pass to special meniu JustasK 10 805 09-12-2018, 10:05 PM
Last Post: htservice
Mercedes Benz w205,w213 easy entry exit coding dkdlqhtm11 10 1,295 09-12-2018, 07:39 PM
Last Post: dkdlqhtm11
