ST10F280 flasher tool software needed
please can somebody share st10f280 flashing tool as i realy need to read iaw 6lp1.01 ecu
i have vag cable to use with software
thanks
Sent from my SM-J250F using Tapatalk
i realy dont get this, probable you try to make money but have not tool to do the job..
buy proper tools if you want to work on ecu's....
Sonder Hash Code & EZS Password Service, Ask via PM
They will have to pry the mouse from my cold dead hand.
Don't PM me for SW keys, Licences, radio codes or similar, you will not get any answer...
(06-25-2020, 11:47 PM)sixcode Wrote: i realy dont get this, probable you try to make money but have not tool to do the job..
sorry sixcode its just this 307 old type ecu I have problem with dont want to spend alot money for this type job as i dont do alot of 307
just need cheap way out only need to read pincode
The X-ROG can read this mcu very easy and the connection diagram is already posted
:devu
(06-26-2020, 09:33 AM)daniersms Wrote: The X-ROG can read this mcu very easy and the connection diagram is already posted
thanks daniersms but i dont have xprog only vvdiprog but it fail for some reson
so I'm trying with st10 flasher tool with blue vag cable
but stil getting an error not sure if im useing the right cable please can some1 help to do it?
thanks [Image: 151f689c0a9ba69bd109f7854143c858.jpg][Image: fc9accac90aa1afcd781e899190dfa82.jpg][Image: faecdd168691e171d7f2eedf905c9fc3.jpg][Image: b275f4e8167ece0e83a01d1cd3aeae3c.jpg][Image: 91a219a601631b41abc909a98becc0fc.jpg]
where is boot pin in your pictures ?
thanks six here same as showed in second pic[Image: 511c251b6ec84ca5765abcce5f88b9ba.jpg][Image: 2cb13302dc7186d7da7bbe714d0af2c3.jpg]
also I'm useing 2 560R half watt resistors to boot mode the ecu not sure if it to low range to do the right job
05-12-2020, 05:18 PM
Renult
03-20-2020, 11:56 AM
03-13-2020, 04:11 PM
02-15-2020, 11:28 PM
