Patient SAAB 9-3 with Opel-Fiat 1.9 diesel.
The car was used without air conditioning for a long time. After removing the leak and recharging, the air conditioning does not work. After short-circuiting the relay that controls the compressor, the air conditioning starts cooling normally. Everything indicates that the engine controller "forgot" that the car has air conditioning. I have heard of such cases, and this is additionally indicated by the values of current parameters read from the engine controller using OP-Com - in the case of parameters regarding turning on the air conditioning, the value field says "not programmed" or something like that. I tried to program it with Op-Com, but where the car configuration is, the air conditioning field shows that it is present, but the air conditioning compressor field is grayed out and marked as unavailable. Has anyone had a similar problem and know the solution?
