  • 91 Vote(s) - 2.78 Average
Saab & Opel PCMCIA Tech2win
37
I just posted a cracked tech2win v2.302 over here:
http://mhhauto.com/Thread-Tech2Win-v2-30...#pid411935
I also removed the card whitelist so it will try and run any normal card. It may be good for you guys with unsupported cards.
Please +rep if its useful for you.
38
(02-28-2015, 09:32 AM)gmtools Wrote: I just posted a cracked tech2win v2.302 over here:
hey gmtools! i tried your tech2win but it doesn't give the "Select vehicle Communication Interface" that my previous versions did, any ideas?
What do you mean with this??
'I also removed the card whitelist so it will try and run any normal card"
What is card whitelist??
The Tech2win v2.302 only in Win7 show you "Select vehicle Communication Interface"
The pcmcia bin files that are not for Tech2win will not works or only that I tested
Suzuki, Issuzu ( only the one of them other is working )
SAAB do not work
This is what I tested
In the rest the cracked version keep the activation no need to release every day
Good luck
Thanks given by: Russel , Damex33
41
Thanks matty you are always a great help,i use windows 7 and that works all great.
Thanks given by: mattydr67
42
(04-15-2015, 01:07 AM)Russel Wrote: What do you mean with this??
Tech2 win knows what cards it will run - the whitelist. I removed that check. It'll try and run any bin you throw at it, saab, whatever. That does not mean it will work, but it does mean you can try.
43
Ok gmtools its clear now, i use it for opel/vauxhall and did already a lot off things without problems.
MTA gearbox programming, some other programming things,etc all works perfect !! .
Again many thanks for sharing this.
I test cracked tech2win and it looks ok. (Win XP)
I also test bin saab 148.000 1998-2012 New_English.bin and he do not work propertly with 9-3 MY08 (he see and pass key status but fail vechicle model year selection)
have a movie from testing. Later i can check with old 9-5.
Checked on genuine mdi.
If you have newest modded bin file i can check them.
Thanks given by: Damex33
45
Any info yet on saab for Tech2Win??? USA version???
Saab
01-29-2020, 11:05 PM
Opel
08-27-2019, 12:58 AM
Saab
07-11-2019, 05:31 PM
06-24-2019, 08:24 PM
