Sd connect c4 error fault: (1.1) - 1.501.9887
Good morning, I have a problem with sd connect c4.
After diagnosing a w251, the interface has stopped working and always gives me the same error:
fault: (1.1) - 1.501.9887 I attach a photo of the error.
I have reprogrammed the pic 18f8680, pic 16lf88 and have changed the serial number of the eeprom at24c02.
The problem I think is in the Caesar that I always get 0.0.0.
I attach the SD toolkit report.
I've gone through all the plate welds on almost every component.
If someone can help me I would be so thankful.
(07-28-2020, 12:43 PM)europhon Wrote: Good morning, I have a problem with sd connect c4.
you will see 4 RAM chipsets on the motherboard. Next to each one is a capacitor. Measure using the short circuit measurement mode with the voltmeter. capacitors never short circuit. if the RAM is faulty, there will be a short circuit during the measurement. I always change 4 RAM. the problem will be solved.
Thanks given by: europhon
Good afternoon, I have checked the ram memories as you have told me.
I have connected the voltmeter on the capacitors and the voltage is always 5.0V in all the memories. K6R4008C1D (4)
I have also checked with the same process the K4H561638 (2) and also SAF-XC161CJ and the voltage in the capacitor is 5.0V.
Is there any more verification?
Best Regard
Goodnight,
have you tried updating Caesar firmware via the SD toolkit?
Good morning,
Yes indeed I tried to update it by SD toolking.
It always gives me this error:
DCDI_eErrorCode = 201
Best regard
Hi.
Try replacing the flash memory 29F016D.
08-10-2020, 12:00 AM
07-15-2020, 09:51 PM
07-07-2020, 09:21 PM
07-04-2020, 02:40 PM
06-17-2020, 11:42 PM
