  • 44 Vote(s) - 3.25 Average
Sdconnect, c3 mux, connection
I used the bootable image 03.2014, and that works, had a problem connecting to my mux, but after some fiddling it did recognize it, but gave me a different problem, now it recognizes the c3 mux, the picture changes from the wireless one to a picture that looks like my c3, so it feels it.
And the red cross over the padlock goes away.
However, i cannot get the padlock symbol blue, or the anything else, and therefore cant run the configure in that menu, so i cannot use xentry/das, because i cant get contact with it, have any of you seen this before?
EDIT: To take it from the beginning, i used an old version of xentry and das working for about a year, then it died, so i thought, ordered a new c3 mux, which didnt work either, so installed new programs, made that working, but still no connection to the c3, so changed files in das/bin and xentry/bin, then retryed still no action, so then i tryed my old c3 which i thought where dead, and this is where we are today, maybe i should change back the files in the bin folders?
-As stupid as i am, i did not save a copy of these...
Does anybody want to share these files with me, its 03.2014...
And when i start Xentry and try diagnosis through it (das) the icon changes from c3 to sd connect, and the red cross reappears over the padlock, and then get errors when das trying to aply communtication layers.
Then when i exit das and xentry, it changes back to c3 icon and the red cross disappears over the padlock again...
So it seems it just partly recognize the mux, or something...
Its seems strangely enough to behave like the one in this thread; http://mhhauto.com/Thread-SDConnect-and-...S-Dev-mode
But, as i stated earlier, ive deleted my old bin files, so im back at trying to reapply the original bin files...
Am i completely lost, or am i on to something here?
Do not, ever, mess with any files in Xentry/bin...
What errors are you getting? What are the numbers? The SDNC icon for the C3 MUX will change in DAS back to an SDConnect but will work fine for everything but online coding...
You should ALWAYS back up files before replacing them...
Thanks given by: ToMiBoY , da14u , webmaster
This behaviour is perfectly fine for a C3, the blue icon is for a C4, your problem is the fixed bin folder, you freshly installed and need that folder..
Like stated above what error numbers are you getting, most likely the fix files. Get back to me on TV and I'll sort out the bin folder for you.
Please press the [Image: postbit_reputation.gif] and [Image: postbit_thx.gif] if my post helped you...
Thanks given by: Rocinante , webmaster
