Siemens Sirius 32
Hi guys, i need help with Siemens Sirius 32 without CAN. Can i read the flash for immo off with KESS/KTAG? If i can't, what should i use?
Thank you
Hello mate, Kess/KTAG will only read partial flash file and not full. best way is to remove flash and read it by programmer
Dont forget to Thanks + Rep If I helped you  Muscle  Nerd
Thanks given by: GAlt
#3
You read it in bootmode with simple VAG com 409.11 kkl interface, all 256kB ok.
No need to remove solder/desolder flash, prone to destroy your ecu.
Thanks given by: stef4o07 , GAlt
#4
(10-11-2018, 06:23 PM)alfabit Wrote: You read it in bootmode with simple VAG com 409.11 kkl interface, all 256kB ok.
How can i do that?
KTAG reads full flash for sure
VT Dyno|Kess|KTAG|MMS|PCM Flash|CMD|AT Tool|HP Tuners|VCP
im also sure that ktag reads it full, as it hooks up with one wire or so to do it in bootmode! already did one in the past with ktag
and was no problem
use ktag to read.
you need genuine ktag or good clone.
i think you will make immo off, just read file and post here and i will do immo off 100% work
Ktag clone ok-Piasini ok Trasdata ok
my ksuite has no option for read twingo mk1 sirius 32...can i try with clio with this ecu?
BMW Bmw E60 Siemens ms45 5wk93018 full backup need with MPC ms_tech 3 100 10-13-2018, 09:36 PM
Last Post: ms_tech
  sirius 34 i need immo off kostrz3 0 68 10-08-2018, 03:32 PM
Last Post: kostrz3
  sirius 32 - immo off mietekfigur 15 1,896 10-08-2018, 01:05 PM
Last Post: ngreg
  SIEMENS PCR 2.1 REPAIR Teoz 5 138 10-06-2018, 03:14 PM
Last Post: razor1199
  Sirius 32 immo tool - new version free for all danyguit2000 51 7,180 10-03-2018, 01:16 PM
Last Post: lozinski1
Users browsing this thread: mikedemirjian, 1 Guest(s)
