  • 2 Vote(s) - 3.5 Average
Sirius 32 1.2L to sirius 32 1.4
Hello everyone,
I've changed sirius 32 1.2 l to other 1.4L tested on a car before,
Now the costumer said that the temperature gauge and the RPM are not working, and it's because of the ECU, ..
SO,, WHAT DO YOU THINK ?
Sent from my Redmi Note 3 using Tapatalk
ecu sirius32 engine 1.2 is full CANbus, ecu engine 1.4 is partial or not CANbus, so not working temp and RPM indicators normally are not working
Thanks given by: stef4o07
(05-31-2018, 05:07 PM)alfabit Wrote: ecu sirius32 engine 1.2 is full CANbus, ecu engine 1.4 is partial or not CANbus, so not working temp and RPM indicators normally are not working
Thank you
Not long time ago I wrote immo off file for twingo 1.2 8V (sirius32N) into ecu sirius32 megane. scenic 1.6 16V and twingo runing and everything is working with megane ecu Kolo[/u]
Hi can you give me the link of the post
(05-31-2018, 06:25 PM)grmsek.damjan Wrote: Not long time ago I wrote immo off file for twingo 1.2 8V (sirius32N) into ecu sirius32 megane. scenic 1.6 16V and twingo runing and everything is working with megane ecu Kolo[/u]
What link?
Ah sorry you wrote a BIN file, I though it was a post here on the forum
07-21-2019, 10:44 AM
Renult
07-19-2019, 06:55 PM
07-17-2019, 01:18 PM
07-16-2019, 01:50 PM
