Smart 451 TCU / TCM coding and flashing
Can this TCU be coded or firmware updated on the bench?
The wiring diagrams suggest it maybe possible, but I'm not sure if the SAM has a role in the process.
Thanks.
Panasonic CF-H2, CF-20 (Win7/10, Xentry-DAS, Vediamo, DTS)
Open port 2.0, VCXSE, C3. (Retired newbie, still learning).
Thanks given by: frikitiki
(02-06-2024, 03:14 PM)Expat_Mat Wrote: Can this TCU be coded or firmware updated on the bench?
Thanks.
Update:
Quick answer: Yes.
Long answer: Yes both DAS and Vediamo.
How:
Grab your favorite VCI (I used SM2 with the bench cable - exposes 12v, Gnd and Can bus)
  12v - pins 1 & 8.
  Gnd - pin 4
  Can Hi - pin 13
  Can Lo - pin 14
  (optional) 12v - Pin 31 (only needed for flashing).
Connect to right hand connector using diagram below.
| 1  2 |  7 .  .  .  .  .  . 14 |
|      | 15 .  .  .  .  .  . 22 |
| 3  4 |------------------------+
|      | 23 .  .  .  .  .  . 30 |
| 5  6 | 31 .  .  .  .  .  . 38 |
Connect with DAS or Vediamo full access to eprom for fault reading/clearing, coding etc.
Pin 31 enables access for firmware updates either by DAS or Vediamo.
That's it.
Matt.
Thanks given by: karlos111 , pesona , LUNA-trans , ricardo_sx , frikitiki
Hi mate
I'm trying to update my TCU but DAS cannot see my cff file, can you please advise what is the procedure with DTS/vediamo? I don't seem to have any 451 files in my library
my car is 451 turbo
hw: 451 545 02 32
sw:4514469095
vin WME4514322K070323
thanks in advance
Easy enough to do with Vediamo
I'll give it a try
It worked, it was really easy as you said
Thank you!
Hello everybody,
Can i use ktag or kess to this job?
Thank you.
