hello,i have smart forfour 454,the problem was to adapt transmission after clutch actuator have been replaced,unfortunately someone deleted coding by mistake,and now the car is not starting again,please someone help me what i can do o make car start,
attached is ecu dump from 24CS08A,and ecu is
Mitsubish Elect
A 135 150 29 79
8631A091
E6T42491 HZE
the vin is still in that file
if no more starting i think you have a softouch gearbox
did you try start the engine with feed the starter directly
because if softouch the ecu engine have bigger file for the gearbox management and if not can check in what gear the car is then it not start
411-28-2016, 10:40 PM (This post was last modified: 11-28-2016, 10:41 PM by ivannzowa.)
(11-27-2016, 07:26 AM)Drehmoment Wrote: with what tool did you read the eeprom ?
THE CAR START FINE DIRECT FROM STARTER,YES HAS SOFTTOUCH GEARBOX
