I see in your error screenshot in the bottom status bar shows SD Connect MUX icon but not C3 MUX, C3 and SD Connect uses different hard drive. It is the correct hard drive?
[email protected]
[Solved] C3 is not connecting with W204
11
10-10-2016, 11:52 AM
(10-10-2016, 11:05 AM)Kim1980 Wrote: I see in your error screenshot in the bottom status bar shows SD Connect MUX icon but not C3 MUX, C3 and SD Connect uses different hard drive. It is the correct hard drive?
Yes, I always use this drive with C3 mux, and there is no problem with connect to other models as I noticed in 1st post. Probably the software on this hard drive is an universal image to C3/SDConnect that seller gave me with laptop :s
After work I'll try to enable W204 in DAS, maybe it will give an effect.
If not, maybe I should use older Xentry (for example 09/2014)?
Any more ideas are welcomed
12
10-10-2016, 01:30 PM
First try in toolkit.ini delete line skipcomports=all and set line usecomport=2 then you will see in SDconnect toolkit PartD on display after mux connection.
(10-10-2016, 01:30 PM)laco210 Wrote: First try in toolkit.ini delete line skipcomports=all and set line usecomport=2 then you will see in SDconnect toolkit PartD on display after mux connection.
Nothing changes :/ (edit - there was no change because I didn't restarted system. After restart work perfect
)(10-11-2016, 06:43 PM)asimor Wrote: Change folder BIN to PartD
Which folder? Can you explain more detail?
15
10-12-2016, 03:20 PM
Hello Decodec,
please copy this two files in the attachment to path--F:\Programme\xentry\llist\
