  • 9 Vote(s) - 3.33 Average
Solved! Many thanks! OpenShell 03/2017 C4 wireless setup issue
[attachment=174289]
Dear Friends,
I try set up for Openshell 03/2017 now.
Set up had no problem (Special thanks for DieTRih)
However stuck wireless setup for C4.
Config a use with ad hoc loader.
Trace setup with instructions.
However won't complete Headbang
OS windows7 professional 32bit sp1 and update lastest
SSD 256 GB / 4GB ram
Laptop Dell E5500
Wired LAN ip address : 172.29.127.100 / 255.255.0.0
Wireless LAN ip address : 192.168.2.11 / 255.255.255.0
C4 config ip address : 192.168.2.10 / 255.255.255.0
ad hoc loaded --> apply password a*26
Then disconnect a LAN cable...but won't change ad hoc icon.
Please check my setup seen. sorry Japanese version.
h + ttps://www.youtube.com/watch?v=4JDpKTgmRjY&feature=youtu.be
I had wrong setup?
And your open shell 03/2017
What Does work other ip address?
Please help!
Best regards,bow
Dear Friends,
Thank you so much for many advide Cheer2
C4 wireless issue solved !
Cause at " wireless adapter configuration " function switch.
Ad hoc --- other name IEEE802.1 and a/b/g...and other.
I use Buffalo WLI-GNM mini USB adapter.
This property " disabled IEEE802.1 " as default. <--- Caution!!!
Won't turn on ad hoc icon and won't select C4.
Turn " Enabled " All is solved .
Change ad hoc icon, Can for selectable C4.
Thanks again Love MHHauto.com BeerBeerBeer
[attachment=174500][attachment=174502]
Did you follow these instructions?
http://mhhauto.com/Thread-xdos-sdconnect...#pid568685
Worked perfectly for me..
Thanks given by: taisuke-san , yriy , pesona
Dear Friend,
I already try this method.
But not successful.
I think mistake in read for this instruction possibly for...
Will try this method once again.
Thank you in your advice! Big Grin
Thanks given by: Rocinante
Tried you click on TkSelection and choose your SDConnect for wlan?
Thanks given by: taisuke-san , Rocinante , pesona
Thank you friend,
I will check with your advice. Kolo
And tell you results.
Regards,
(03-16-2017, 10:50 PM)laco210 Wrote: Tried you click on TkSelection and choose your SDConnect for wlan?
