  • 26 Vote(s) - 3.04 Average
[Solved] Xentry 09.2014 start problem "Failed to launch program or document"
Hi guys,
I've put disk from old D630 to new D630, inserted starts keys to xentry, das, then I got an error "Failed to launch program or document" and "System cannot find the file specified".
[Image: bk4mjwhl.jpg]
Anybody can help?
TAKE a look at partition letters,probably one letter is different and specified path cannot be determined!
(08-26-2015, 05:07 PM)weryo Wrote: TAKE a look at partition letters,probably one letter is different and specified path cannot be determined!
[Image: a6dkd3ew.jpg]
This is a guess as I am way over my head tech wise----but-----Did you keep the same HWID or change the HWID!!
Sweating i have same trouble
pls help
That virus at xentry.exe.. symantec already eat your file see.. at folder xentry bin..
you will not found xentry.exe
regards,
Edit : replace this file to your xentry bin
then kill process Tomcat7.exe if you found it at task manager
.txt
xnetry.txt
91
70 bytes
[Image: signaturemhhauto.gif]
(08-26-2015, 07:53 PM)Yudi Wrote: That virus at xentry.exe.. symantec already eat your file see.. at folder xentry bin..
regards,
Yudi Give5
In fact, Xentry.exe was deleted probably by antivirus program. Thanks a lot!
Thanks given by: Rocinante
regards,
HI
I GOT THE SAME PROBLEM, REALLY APRECIATE IF YOU GOT THE FILE
