  • 14 Vote(s) - 2.86 Average
Sprinter 2008 No Crank
10
So that first EEPROM is what I recently read from the EZS.
Attached is the EEPROM that I used after I wrote key #1 using Tango. I rewrote this eeprom back into the EZS, and same problem.
Is the flash good?
A906 545 48 08 MC9S12 EE SEC Key #1.rar
1,017 bytes
I do not know how you read it but what I see either your progger sucks or your file is totally corrupt. Please post your VIN here (just do not post last 4 digits for privacy) Either its from Zimbabwe , Ivory Coast or so or the file is corrupt. I do know the structure of a normal 906 dump for euro or USA sprinter - this is something either terribly screwed up or I do not know something. As of my understanding I don't even imagine how something like that can start. I f you look at address starting 40 and ending 60 you shall recollect your VIN number. in this case its not sprinter vin number as far as I know
My old contributions are not password protected. Get them if you need them. I will delete them in order to make space for new ones.
I'm in Canada and this is a Sprinter made for Canada.
Smok Original. Tango Original. I did a Sprinter 2007 same EIS 2 days ago and followed the exact same steps, that sprinter is working fine to date.
But the first sprinter is what I have problem with. I'm thinking it's a mechanical because it worked fine the first day. It was bought from an auction and I went there to make a key.
I will get the VIN.
Note tango accepts all the EEPROM file I provide.
I do have some dumps for US sprinters. I would like to see your VIN. Flash looks ok. Nothing wrong there
Thanks given by: autokeypro
14
WD0BE84568529****
Yep would be nice of you to mention in the begining that it is a transponder key for NA market. This is why your dump looks like a mess for me. Sorry I cant help you there with key problem.
Thanks given by: Rocinante , autokeypro
16
(01-21-2017, 03:00 AM)autokeypro Wrote: WD0BE84568529****
first need to make in this moment diagnose with star , on eis and cdi , and put here pictures.
second in most cases elv is wrong, mechanical pb. ,can use older or second hand elv with motorola inside , but need make virgin.
also , in this moment your key , rotate in contact , and relase elv?? is very important!!!
if yes eis and elv and key is ok.
need more details about your pb. and can contact at: [email protected] or [email protected]
Ovidiu1967 careful with old style ELV with motorolla .... its an NAFTA EZS..... there is no coding ELV old or ELV new on it....... (not like 906 euro where you can install ELV with motorolla and code EZS to ALT) it is stated above that this is NAFTA EZS with transponder key. and this EZS has nothing to do with 906 EZS or LT3 EZS (crafter).
Okay have a question, does the EIS have a rolling number with the ECU to allow the car to start?
So let's say I do a job for this vehicle and make a key, then customer decides to get key from Mercedes, can I write the original EEPROM back in the EIS to get it back to original condition or the ECU has data that synchronized with the EIS EEPROM?
