Sprinter 906 EGR problem
I need solution for EGR off with plug disconnect. I try a many time but always after 2-3min on idle give me 2527-004 and limp mode  Fing20 Can someone correct my file?
On attached original and my try with DPF off.
Fing32 If I helped you please remember to give thanks and REPUTATION. A little thanks goes a long way Handshake
(07-08-2019, 11:05 AM)forfiter Wrote: I need solution for EGR off with plug disconnect. I try a many time but always after 2-3min on idle give me 2527-004 and limp mode  Fing20 Can someone correct my file?
rep and thx.. pass in pm
Thanks given by: forfiter
You are just wasting your time, many successful tuners do their very best to work maps closely around what the manufacturer does, For example on trucks V6 engines have 310hp, 350hp, 360hp, 400hp, 440hp, 460hp &480hp output for Mercedes benz OM501LA so lost of tuning success is gain by using these flash files. There's a factory solution for the respective vehicle, you should get the cdi file for the Sprinter in the SA market.
“We, the unwilling, led by the unknowing, are doing the impossible for the ungrateful. We have done so much, for so long, with so little, we are now qualified to do anything with nothing.”
Thanks given by: Mirnel
05-29-2026, 01:23 PM
05-21-2026, 01:03 AM
05-09-2026, 02:02 PM
