  • 6 Vote(s) - 2.33 Average
Sprinter 906 LED Sidelights
Have installed LED sidelights on my sprinter 906. Connected up and work great however there is now an error code on the dashboard. (open circuit).
Assume this has got something to do with the much lower power consumption now, but is there either a way to over ride and activate this in DAS or do i need to put resistors in the circuit?
If anything you will find the coding in front Sam use vediamo.
Magpro-Flex-BitBox-Ktag-Kess-Nexiq2-AutoHex-Xentry VCI-Icom-All Vvdi
(03-04-2017, 09:54 PM)charles.soori Wrote: If anything you will find the coding in front Sam use vediamo.
Thanks yeh was going the vediamo route as second choice but would prefer SCN way if possible.
Found on Vediamo - SAM906 - IO Control - Seitenmarkierungslichter
Assume this is what i need to deactivate on both the left and the right? Would this stop it picking up and error code?
