Thanks Given: 1
Thanks Received: 1 (1 Posts)
Hi there
Anyone here able to remove the 90km/h limiter from a 2019 Sprinter? It's a 519 with dual rear wheel and tacho ect.
Have vediamo here so hopefully can do via teams viewer.
302
Thanks Given: 958
Thanks Received: 1496 (682 Posts)
1,567
19
09-25-2020, 03:06 PM
(This post was last modified: 09-25-2020, 03:07 PM by W214.)
Yes. I can do. But vefiamo is unstabil woth new files. Better use dts
Thanks Given: 1
A big thank you to W211 who removed the limiter this afternoon.
10
Thanks Given: 26
Thanks Received: 57 (35 Posts)
135
41
I have 2021 Sprinter with CPC unit , I changed speed limiter with Abrites on CPC unit , but vehicles still limits at 100 km/h do I need to do it on ecu aswell , because I cant see option to do it on ecu? Ecu is CRD3P.C0
208
Thanks Given: 80
Thanks Received: 488 (157 Posts)
576
46
Maybe you changed in wrong place. If need I can help unlock cpc_ng and change limiter
25
Thanks Given: 202
Thanks Received: 128 (53 Posts)
192
30
Not possible in Xentry under developer function?
0
Thanks Given: 0
0
hi i also need this service to remove the speed limit from 907 2020 please contact me
