  • 47 Vote(s) - 2.72 Average
Star C4 Sd Connect Lan connection problem
10
Disable in network settings "1394 connection" and try it again.
(11-06-2015, 12:29 AM)croman91 Wrote: I don't know what do you exactly mean. Name of mux 00 means that is like factory setting. On my laptop you can see number 21, beacuse i was one day able to connect laptop and mux together. I tried also to connect my mux to new installed Xentry on another laptop, but here i get same problem. I think there is problem with the Lan unit inside the mux. I opened it 2 times to check every cable but nothing i cant see what cause this lan connection problem.
At the time you were able to connect to your mux, the mux name was "21".
(11-06-2015, 12:42 AM)laco210 Wrote: Disable in network settings "1394 connection" and try it again.
Allready tried disable 1394 connection" but no luck.
Yes. The mux name was 21 an everything was working well. But at the next day my plan was to do an firmware update of mux. So first i decide to connect again Laptop with mux but this connection goes wrong and i tried to change some settings on laptop. With no luck to solve connection problem i decide to reset my mux.. so here i am with my mux with factory settings and no lan connection more.
Try different computer and different lan cable.
If you still get no link status of network your mux is dead like other china AAA quality toys.
You will do nothing without link. Link means LAN hardware is physical linked with cable.
  • SW Seed\key VGS\MED\IC virgin\hard coding Carplay HU5s1 HU5es2 any fw
  • HW Genuine XentryConnect-SDConnect-eCom sale\repair\parts\setu
Check that you have not lost IP address of the network card on your pc
if you have lost it can display 00 which I think you are describing.
You could set any IP in network card, or no IP(DHCP), but you will still be able to see SDConnect as cable connected device in Toolkit Admin window table.
Thanks given by: laco210 , JarsaR
16
(11-11-2015, 05:40 AM)Anturage Wrote: You could set any IP in network card, or no IP(DHCP), but you will still be able to see SDConnect as cable connected device in Toolkit Admin window table.
Dude, tried allready another IP adress. No connection. I was searching how do delete configuration on toolkit like factory reset. Do you know how can i delete my settings by toolkit of 21 mux? After taht i can try to get connection and save as a new mux number by toolkit! Maybe this can solve my problem
Read post #13 again
(11-12-2015, 04:08 PM)Anturage Wrote: Read post #13 again
OK. I understand. DEAD! Sweating
Is there any solution to repair it? I heared about one user here on forum who repairs mux like sd coonect c4! Maybe it can be flushed manually with new firmware by special tools/programmers.
Thanks for any help and best regards.
