  • 3 Vote(s) - 3.67 Average
Start Error
Year of manufacture 2001 motor 1,6 MT
The car was brought a week ago after 2 weeks ago the ECM was sent to me in which I found various soldering work which however did not give much meaning. The reason for this is according to the workshop: Start Error
StarDiagnosis, WSP and MSG all errors cleared is the right one, is acknowledged, all OK what is missing is the CAN message to the ECM, and that is the reason for start error.
The control part of the injection has CAN -contact to the AI, ABS, AirBag and everything else except the WSP !!
Have here mail a screenshot of the Oszi.mit uploaded. Ie high and low are available at the WSP module. Since I have another case here, W638 with the same symptoms I have parallel with this already cable, thus between WSp and ECM to exclude possible damages on the way there, but it has not changed.
In both vehicles I replaced ECM, WSp and key, through Kit's which I have tried before in other vehicles and found as good .... only in these two is nothing.
Has there anyone experience ??? Chris
Hi. Somebody probably soldered emulator into ecu due to immobiliser error or lost keys. Part of this process means cutting can wires to wsp. Usually this is done near to plug on wsp.
WSP will still communicate on k-line. I'm sure if you look on the car you will find cut wires.l
Thanks given by: cksoluciones
