  • 34 Vote(s) - 2.74 Average
Stertkey problem
Hello,i have tried with several keygen to insert the key,save is succesful but then says ''startkey center unable to identify profile''
plus every time i close xentry it loses the key.
On startkey diagostics says ''StartKey server query was not successful: no compatible StartKey found on the server.''
See 7.8 here... http://mhhauto.com/Thread-DAS-Xentry-201...Links-Here
Thanks given by: ToMiBoY , takis , DBmhh , Yudi
(01-14-2015, 06:55 PM)Rocinante Wrote: See 7.8 here... http://mhhauto.com/Thread-DAS-Xentry-201...Links-Here
Something more specific please?
Perform the steps in the link 7.8 ..
(01-15-2015, 12:15 AM)Rocinante Wrote: Perform the steps in the link 7.8 ..
I have done this and now i have a Javaw.exe problem....Sadsmile
Well, then that sounds like a different issue... Make sure you have made the right files read only and not-read only...
Also, if you don't post a picture, or give more info on the java error, we can't help you..
Thanks given by: Yudi , ToMiBoY
(01-14-2015, 04:35 PM)Giannis1980 Wrote: Hello,i have tried with several keygen to insert the key,save is succesful but then says ''startkey center unable to identify profile''
Hi member, I have the same problem to you when I installing xentry openshell when I activate the key it says successful but the ''StartKey server query was not successful: no compatible StartKey found on the server.''
please help me how to fixed this.
