Strange problem with missing coolant temperature 8R
Hello everyone, first sorry for bad English smile
I want to ask for some help, if someone faced same problem.
Car is Q5 2010 year CGLB motor.
After swap Instruments cluster with facelift, didnt have coolant temperature at all. Something happen and cluster read it 0.00 degree.
What i do:
Test with 2 clusters, same thing - not cluster problem. After return to prefacelift cluster coolant temp is shown correctly.
Test with every possible index version facelift cluster - 0 coolant temp.
Test with facelift gateway 8R - 0 coolant temp
Run cluster at table, show -48, they see that coolant info missing and as usual show -48/-50
Update every possible module to latest version - 0 coolant temp.
Now the only thing maybe is ECU. Collant temp sensor is simple wired. Just go to ECU and ECU send it to CAN wire. Maybe something mismatch about CAN signals and I want to flash it with different version again for CGLB motor.
My ECU is 03L 906 018 ML HW:21 - maybe too old, but possible latest version for them is 9977.
Test cluster in A4 car where ECU is with flash version 9978 and show temp.
For my engine ECU what i found in internet is 03L 906 018MQ and ML. MQ have 9978 flash file but its HW:25 not 21.
Can i flash it with ODIS to make it from ML to MQ?
06-01-2026, 12:14 PM
03-31-2026, 07:04 PM
01-31-2026, 03:30 AM
