Hi.
Is there anyone with working solution for deleting secondary air system from Subaru Forester 2.0 116kW 2007?
Will pay for it. If you don´t have solution or are not sure, don´t reply.
Present fault codes P1410, P2444, P2433
All secondary air pump related codes are:
P0410 - SECONDARY AIR PUMP SYSTEM
P0411 - SECONDARY AIR PUMP INCORRECT FLOW
P0413 - SECONDARY AIR PUMP A OPEN
P0414 - SECONDARY AIR PUMP A SHORTED
P0416 - SECONDARY AIR PUMP B OPEN
P0417 - SECONDARY AIR PUMP B SHORTED
P0418 - SECONDARY AIR PUMP RELAY A
P1410 - SECONDARY AIR PUMP VALVE STUCK OPEN
P1418 - SECONDARY AIR PUMP CIRCUIT SHORTED
P2431 - SECONDARY AIR PUMP CIRCUIT RANGE/PERF
P2432 - SECONDARY AIR PUMP CIRCUIT LOW
P2433 - SECONDARY AIR PUMP CIRCUIT HIGH
P2440 - SECONDARY AIR PUMP VALVE 1 STUCK OPEN
P2441 - SECONDARY AIR PUMP VALVE 1 STUCK CLOSED
P2442 - SECONDARY AIR PUMP VALVE 2 STUCK OPEN
P2443 - SECONDARY AIR PUMP 2 STUCK CLOSED
P2444 - SECONDARY AIR PUMP 1 STUCK ON B1
Ecu is Hitachi and flash is read with MMC-flasher.
SW-number: 4E44307106_D1684EC3
Processor: WA12212970WWW
PowerSport Calibrations ATV-tuning solutions
The original author of Siemens Simtec 70/71, Delco HSFI-2.X and Audi Multitronic repair instructions. (Press rep if they helped you during these 15 years)
