29
Thanks Given: 440
Thanks Received: 130 (39 Posts)
247
62
I'm searching to buy a Suzuki VCM to work with SDT-II
Is it possible to flash a Ford VCMII to become a real Suzuki VCM with VCM manager and other way maybe
29
Thanks Given: 440
247
62
Yeah, great to beggin.
But Run with "old" Ford VCM Firmware.
If Suzuki VCM firmware are more update than Ford, It's possible to get some problem with some ecu.
It's not possible to program a Ford VCM like a Suzuki VCM
709
Thanks Given: 2326
Thanks Received: 2447 (816 Posts)
2,014
125
I use a vcm 2 from ford with the latest suzuki software,and i never had any problems..
The only (-) is the immo function...
If i Helped,please press thanks and +rep buttons
671
Thanks Given: 1490
Thanks Received: 5080 (2564 Posts)
4,100
0
02-16-2018, 11:13 AM
(This post was last modified: 02-16-2018, 11:14 AM by mattydr67.)
(02-16-2018, 01:00 AM)jerome110383 Wrote: (02-15-2018, 10:36 PM)Stelaras Wrote: I use a vcm 2 from ford with the latest suzuki software,and i never had any problems..
The last version of sdt2 is february 2018.
Where did you buy your Ford vcm
There are something To look point of view quality
What version of ford vcm manager did you use
Use Ford VCM2 with VCM 2 Manager v2.1.1.5
You will find this Manager version in Ford IDS v86
Good luck
Reverse Engineering OP-COM Rev. D+, OP-COM Rev. E+. OP-COM Professional, OP-COM Advanced, TECH2, GM MDI, Ford VCM2, Toyota Mongoose Pro2, AVDI, Multiecuscan 6-in-1 Adapter.
671
Thanks Given: 1490
4,100
0
02-18-2018, 02:25 AM
(This post was last modified: 02-23-2018, 12:43 PM by mattydr67.)
(02-17-2018, 11:17 PM)jerome110383 Wrote: (02-16-2018, 11:13 AM)mattydr67 Wrote: (02-16-2018, 01:00 AM)jerome110383 Wrote: (02-15-2018, 10:36 PM)Stelaras Wrote: I use a vcm 2 from ford with the latest suzuki software,and i never had any problems..
Good luck
Is it possible to use a Newer Ford Manager?
ex : 2.3.85.7 ?
Actually No
I think if you use a clone the last Manager version should be v2.1.119.3
And if its a genuine one the Manager could be 2.1.119.19
No new one.
Good luck
0
Thanks Given: 88
Thanks Received: 30 (11 Posts)
39
I can not find the manager v2.1.103.3 to try out my Vcm2 with Suzuki.
I tried with the v2.1.119.19 , everything seems ok but does not communicate with the car.
You could give me a link where to find this manager?
Thanks.
Luca
