TGV delete on Subaru
Who has the knowledge to do this type of work? The unit is Denso.
Subaru Impreza 2001 WRX 218hp.
(06-24-2019, 06:59 PM)Angelo Wrote: Who has the knowledge to do this type of work? The unit is Denso.
Attach ecu read and Dtc with TGV unplugged
Chiptuning DynoTested
File services - DPF/EGR/DTC Exc
PCR2.1 Full Clone - Edc17 Full clone
/t.me/Edc17tricore
Solution is delete dtc?
Yes, unplug and delete dtc will work
/t.me/Edc17tricore
Thanks given by: Angelo
You need to change the lower intake runner with one without TGV and remove the codes inside the bin of your ecu.
You also need to change couple maps to make sure your engine run perfect.
Subaru subaru.svg
Yesterday, 08:01 PM
06-09-2026, 06:43 PM
06-09-2026, 05:02 PM
