Update: Trailor Hitch OE is coded in car, Problem: in Drivers Display it shows an Event Light -> Trailor Hitch . Center Display not fully integrated yet, shows only Trailor Route Updates. No Button or Selection Menu. But if someone could help me make the Event Light dissapearing correctly woudl be fine for me, as everything else works perfectly.
TM205 variant coding help
I have installed a good AED the towbar module etc works fine while ignition is switched on. If i turn off the ignition and lock the car towbar etc will no longer operate from the switch. Can anyone help me please? Coding was done using DTS Monaco.
21
05-18-2026, 10:29 AM
Hello Guys, Update: My Trailor Hitch ist now coded incl. SA Code 550, finally. A Trailor Hitch Expert Company coded it in first step, but there is no other way than go to MB Store to Final Code it in perfection. Cost 170 € for MB and 120 € for the Trailor Hitch Expert Company. But the 120 € could have been saved. If you are not correclty coding into HeadUnit your stuff. The Head Units Displays will alternate a Error until it eventually doesnt work at all!! Thats the point just a warning. Dont mess it up..
