383
Thanks Given: 922
Thanks Received: 1396 (515 Posts)
1,230
169
01-10-2014, 11:20 PM
(This post was last modified: 01-10-2014, 11:31 PM by KG7222.)
I want to learn how I can update firmware with star diagnosis on NTG2.5, NTG3, NTG4 and etc. I have star diagnosis 2013, but I haven't online access. Can anybody help me? Thanks
2,095
Thanks Given: 14574
6,536
46
You need online SCN coding access..
euror
Location OfflineJunior Member
Thanks Given: 223
Thanks Received: 121 (66 Posts)
137
First of all you need access to SCN coding server, and then insert the designated Telematics disc into headunit, that's all.
vincha7
Thanks Given: 124
Thanks Received: 26 (10 Posts)
45
facing problem with NTG 3.5 software. Decided not to create a new post about software update.
The display shows that the comand software is missing or corrupt and in DAS the error is the same (it happened after dealer update, but it is not the main thing. Before comand had it common failures of switching(display) on and off, sound on and off also, etc..).
The main questions are:
1) tryed to start in DAS offline programming of comand - got:
car is not documented in vedoc... in consequience das didnt give me a number of TELEMATICS disc. Is it possible to update/reupdate software with DAS 2015/09 with offline programming??
(Mr. DieTRih helped me to unlock offline programming 2015/09 and he is the best solutioner of software problems.) Is it posiible to know a number of Telematics disc with offline programming?
2) I have read many posts about updating comand 4.0, 4.5, 4.7 by using vediamo. Had anybody tryied to update(in my case install) software ntg 3.5 using vediamo?
MB number HW: 2218702095.
and
# HU221EVO
[2218702095-XXX];
# SOFTWARE_TELEMATIK_HU_BOOTLOADER_E24
2219024201-001 \HU221EVO\090904\A221902\4201_001\;
# SOFTWARE_TELEMATIK_HU_ECE_NAVI_APPLIC_CODE_E29_1
2219025602-001 \HU221EVO\101605\A221902\5602_001\;
# SOFTWARE_TELEMATIK_HU_ECE_NAVI_APPLIC_CODE_E29_8
2219027502-001 \HU221EVO\104803\A221902\7502_001\;
# SOFTWARE_TELEMATIK_HU_SAU_NAVI_APPLIC_CODE_E35_2
2219027801-001 \HU221EVO\102002\A221902\7801_001\;
# SOFTWARE_TELEMATIK_HU_SAU_NAVI_APPLIC_CODE_E35_8
2219029102-001 \HU221EVO\104803\A221902\9102_001\;
I`ve looked in many versions DAS/Xentry for *.cff's. Didn't dind. Are these *.cff in MB factory only?
Attention and help is the...
