Tiguan MG1CS011 ORI and MOD
i never did MG1 mod and i decided to buy mod file, i ask for stg1/2 with rear lambda off, speed limit and rpm limit.
i need someone to check this file before write.
thanks in advance
.zip
TIGUAN 1.5 TSI 110 KW_MG1CS011_05E906018BC_9597_10SW049887_IntFl.zip
11
2.89 MB
.zip
1.5 TSI 110 KW_MG1CS011_05E906018BC_9597_10SW049887__Stage1-NOCS_IntFl.zip
11
2.89 MB
Your knowledge with Logs can give answer to your questions  Drive
No need to insult other works here Big Grin
shqipe
Thanks given by: ecu035
why is it that people have no confidence when 'buying' a file?
but i bet if file was given free itll be flashed and tested by now....
its strange for me to see this, the place where file is bought from should be the condition of whether there is enough confidence to flash
good tuning is not free, free tuning is not good  Wink
i run garage but file service possible
Stage1/2 EGR DPF Adblue Swirl DTC etc
(11-13-2026, 08:52 PM)carmageddon Wrote: i never did MG1 mod and i decided to buy mod file, i ask for stg1/2 with rear lambda off, speed limit and rpm limit.
thanks in advance
find a trusted and serious tuner to do your job....file is crap
I would asking at selling thread for someone tuner with experience to that ecu and make a good work! Fing32
I would like to help....!!
When you help, you will get help back!
Magpro2 x17.
my goal was just to see if someone could technically evaluate a piece of work, but i see that everyone focusing on everything except giving a technical opinion. I m only seeing judgments about people and their choices, and not a single person has explained why the mod isn't good even the ones who messaged me privately... everyone an expert.
look, i believe buying a mod from a professional is better, but I d actually like to learn something from this mod, and the person who sold it to me isnt willing or able to explain anything. thats why I think its fair to ask we re on a forum, and isnt that what a forum is for, right?
i also want to say that buying a mod doesnt automatically mean its done professionally or with real knowledge...on the flip side, getting a free file for solutions or tuning has always worked out fine, so where is the line between right and wrong? i have bought tunes from well known web professionals that turned out to be totally shameful in terms of power and torque, so i think everyone should ask themselves whether buying from a pro or getting a free file is really any different. unfortunately, you just have to get lucky, and thats a pretty sad reality
Thanks given by: tsiLeon1p
Yes, I did message you privately, and I’ll say it again: my only goal was to warn you—not to sell you a file, and not to badmouth anyone. Now you're sarcastically calling everyone an "expert." Ironically, yes, I actually am one, with deep calibration experience on Bosch MG1 / 1.5 TSI (EA211 evo) platforms.
You complained that nobody gave you a real technical breakdown so you could learn from it. Since you asked for facts instead of opinions, here is your free, OEM-level technical evaluation of why this file is a ticking time bomb:
- Fuel Rail Pressure (35 MPa -> 40 MPa): Raised from 350 bar to 400 bar across the board. Without hardware upgrades or proper injection window/SOI recalibration, pushing 400 bar stresses the HDP6 pump and injectors unnecessarily—especially on a Miller-cycle engine that doesn't even need it for moderate power gains.
- Low-Pressure Fuel Pump (LPFP): The electric fuel pump duty cycle map was maxed out to 100%, completely ignoring Bosch's hardware specification of a 98% max duty cycle (needed for pump diagnostics and driver stage protection). The battery-voltage-dependent max duty cycle curve (codewords) was maxed out right after.
- Global Ignition Advance (+3.75°): Flat +3.75° added across all ignition maps and the entire load/RPM range. On a high-compression (12.5:1) Miller-cycle 1.5 TSI, blindly adding global timing without proper knock margin and EGT calibration is a textbook "percentage-tuner" mistake.
- RPM Limiter (6,500 -> 7,500 RPM): Raised by 1,000 RPM on an engine whose small VTG turbocharger is completely out of its efficiency island well before 6,000 RPM, while putting the valvetrain at serious risk.
- Knock Control Adaptation (IKCtl_ratLoadRngAdpnM1_GT): Knock control adaptation for load ranges 1, 2, and 3 has been altered. Messing with knock adaptation thresholds while simultaneously adding +3.75° global timing actively blinds the ECU's ability to protect the pistons from pre-ignition/knock.
- Torque & Power Limiters: Completely botched—non-zero values were written into cells that are explicitly defined to remain at zero.
- Component Protection / Limp Mode Disabled: Instead of calibrating the torque structure properly, critical engine safety nets were simply switched off:
  * EngDem_tqLimnCamsftErr_T (Torque limitation during camshaft/VVT errors)
  * EngPrt_tqOilOvhtPrv_M (Torque limitation for oil overheating protection)
- Corrupted Axis Data in KFLAMHAP: In the target lambda map for homogeneous operation, someone made a classic copy-paste mistake and swapped the map axes, completely scrambling the fueling targets relative to load and RPM.
You wanted to learn something from this file—well, there you go. You just got a complete, professional calibration audit for free. I have zero interest in selling you anything or competing with whoever made this file; I just don't like seeing people destroy their engines over amateur WinOLS edits.
If you still think this calibration is fine, go ahead and flash it—and feel free to post some high-resolution logs (ignition timing retard per cylinder, specified vs. actual rail pressure, lambda, and EGTs) so we can all evaluate the results together. Good luck with the car.
signatur2
Thanks given by: autobirotula
i spoke in general terms without accusing anyone...i simply wanted to prompt a response from someone who claims to be an expert on the forum, yet hides when the time comes to actually prove it.
i appreciate your assessment, i m glad that someone is helping the forum and me in this way. this is how things should always be done. personally, i help whenever I can free of charge, and only with matters i m actually knowledgeable about, without making anything up. that said, id like to understand how to fix this "ticking time bomb." Thanks.
(11-14-2026, 01:54 PM)carmageddon Wrote: i spoke in general terms without accusing anyone...i simply wanted to prompt a response from someone who claims to be an expert on the forum, yet hides when the time comes to actually prove it.
before doing stg 1  check if the car is already updated with the last factory sw update to avoid kangarooing effect...then make a carbon clean on intake valves cause these 1.5 engine tend to accumulate carbon very soon and dont perform very well.....then get a proper stg1 file and flash it....
