  • 32 Vote(s) - 2.69 Average
Tool for read Mercedes w204 c200 Delphi CRD2
Hi guys! Does any know a tool for read this ecu? I'm trying to read with a clone of galletto v54 but no results. Any know a cheap tool for read this by obd? or, the BDM is best option? Thans in advance!
It should work obd if it's crd2.xx
Sent from my GT-I9100 using Tapatalk
(09-04-2015, 08:32 PM)wiski Wrote: It should work obd if it's crd2.xx
When I try to read the unit give me an error. In the sofwtare info about the unit says "Need 2012 OBD Tool"
well 2012 obd tool is what v54 supposed to be. Did you check ecu label what type it is? It's easy just take engine cover off.
F*ck! I think this motor has got the CRD2 unit but not. It has got a CRD11. Galletto cant read/write this unit. Can I read this ecu by OBD or only via BDM?
Only bdm. But take caution it's delphi reversed.
Thanks given by: MaiiQ
If work fine v54 no problem on this car. I Have read/write crd 3.5 w204 on fgtech v54 eu.
(09-05-2015, 01:45 AM)ninolino Wrote: If work fine v54 no problem on this car. I Have read/write crd 3.5 w204 on fgtech v54 eu.
sure it does but he is dealing with crd.11 (dcm3.2)
09-09-2019, 11:33 PM
07-21-2019, 01:57 AM
07-03-2019, 05:21 PM
05-27-2019, 03:22 PM
05-01-2019, 07:34 AM
