Toughbook Hacker v1
64
I never have used that software to flash anything. Just buy yourself a EZP2010 and clip on to the chip and click connect. Erase the chip then use the file I send you to program it back with. Works every time
The interface is very simple to work with 5 buttons is all you would need to push
[Image: EZP.png]
License Tools + Stuff. Just ask
Thanks given by: DTLD
65
(01-16-2020, 01:34 AM)Veritas Wrote: Hi,
Could you remove the password from this cf-19?
https://we.tl/t-Pr32fTU6lX
Thanks.
Sir, no need to re-flash bios. I was able to decode your password. Your password is ( mcintyre ). Have fun and good luck. I am unclear about Caps or not keep this in mind, as you move forward.
Thanks given by: Veritas , gabi2013
66
Thanks.
Hi Sam102,
I really appreciate your effort decoding the password but unfortunately I've already reflashed the bios and it's working smoothly.
Kudos to you!
Thanks.
Hi Sam102,
Kudos to you!
No problem
People if you got a CF-19/CF-30/CF-U(x) You do not need to re-flash bios. Just dump and I think I can decode the Password. I am almost able to do the CF-53 decoding and I feel like once I have the SHA-1 Hash worked out MOST others will fall. Like the one everyone is waiting for the CF-31. But working out this hash is time consuming to say the least.
Thanks given by: merecedes500e
68
Like promised I would do. Here is the first working copy of the decoder. It only works on older CF-xx models. If it's as new as a CF-53 or newer this tool will NOT work to decode password. This tool also does not do all the work. You must XOR it yourself http://xor.pw/# using the
secure code "5b93b62611ba6c4dc7e022747d07d89a332e8ec1e95444e89f7bfa0e55a2b0350bc9665cc1ef1c837716d2a92d3d88d0e3633ef7998af41d4fb1aa4405d8606b"
Overlook or ignore all (0x80's), (0x00's)
Then take that string and feed it to this program and it will tell you what that password is.
Program is not packed or locked. There's no virus in it look for yourself.
Panasonic BIOS Recovering Tool.rar
96
10.15 KB
Thanks given by: gabi2013 , B4RTJ , automotive_mhh , igor51 , rp1210a , embe , Isrraelito
69
IF you have any of these models here (CF-18, CF-19, CF-27, CF-28, CF-29, CF-30, CF-48, CF-50, CF-51, CF-72, CF-73, CF-74 , CF-M34)
You in very good Lucky Today. These are all the tools to Change the S/N of bios Chip.
I Posted Everything I found. Just took a little looking but there opened where the public can access the
Name Size MB
How to.txt ......................... 0.00 MB
------------------------------------------------ CF-18
18m1bl13a.zip .................. 0.51 MB
18m2bl10.zip .................... 2.98 MB
--------------------------------------------------- CF-19
19m1bl15.exe .................. 0.75 MB
19m1ecl11.exe ................. 0.22 MB
--------------------------------------------------- CF-27
27m3b10d.exe .................. 0.32 MB
27m3b13e.exe .................. 0.36 MB
----------------------------------------------- CF-28
28m2bl12.exe ................... 0.46 MB
28m2bl13.zip .................... 0.40 MB
28m3b11a.zip ................... 0.37 MB
----------------------------------------------- CF-29
29m1bl12.zip ................... 0.48 MB
29m1bl13sc.zip ................ 0.43 MB
29m1bl14.zip ................... 3.36 MB
29m2bl16.zip ................... 0.43 MB
29m2bl17.zip ................... 3.06 MB
29m3bl13.zip ................... 2.89 MB
29m4bl11.zip ................... 1.94 MB
29m4bl12.zip ................... 1.72 MB
29m4bl14.zip ................... 0.49 MB
29m5bl13.zip ................... 0.50 MB
README.txt ..................... 0.00 MB
---------------------------------------------- CF-30
30m1bl18.exe .................. 0.77 MB
30m1bl19.exe .................. 0.76 MB
30m1bl191.exe ................ 0.77 MB
30m1ecl10.exe ................ 0.23 MB
BU30M2.exe .................... 0.09 MB
HowTo.txt ....................... 0.00 MB
--------------------------------------------- CF-48
48m1bl11.exe ................. 0.34 MB
48m4bl13.zip .................. 0.35 MB
48m5bl10c.zip ................. 0.53 MB
48m6bl10.zip ................... 0.54 MB
--------------------------------------------- CF-50
50m2bl10a.zip ................. 0.35 MB
502kel13.zip .................... 0.09 MB
--------------------------------------------- CF-51
51m3bl10.zip ................... 0.60 MB
51m3l20.zip ..................... 0.60 MB
---------------------------------------- CF-72
72m1b10a.exe .................. 0.32 MB
72m1b10b.exe .................. 0.41 MB
72m3bl15.exe .................. 0.42 MB
72m4bl11.zip .................. 0.36 MB
---------------------------------------- CF-73
73m1bl14.zip ................... 0.44 MB
73m2bl12B.zip .................. 0.53 MB
---------------------------------------- CF-74
74m1bl15.zip .................. 0.59 MB
---------------------------------------- CF-M34
34m1bl11.exe .................. 0.49 MB
34m2bl11.exe .................. 0.42 MB
34m3b21m.zip .................. 0.36 MB
34m3bl21.zip .................. 0.36 MB
34m4b14m.zip .................. 0.39 MB
To Make MS-DOS BootDisk
Rufus Win10 Fix.exe .......... 1.26 MB
OS BootDisks
DOS4.01_bootdisk.iso ......... 1.66 MB
DOS5.0_bootdisk.iso .......... 2.21 MB
DOS6.0_bootdisk.iso .......... 2.36 MB
DOS6.21_bootdisk.iso ......... 2.32 MB
DOS6.22_bootdisk.iso ......... 2.83 MB
Win95a_bootdisk.iso .......... 2.60 MB
Win95b_bootdisk.iso .......... 2.76 MB
Win98_bootdisk.iso ........... 2.60 MB
Win98noram_bootdisk.iso ...... 2.87 MB
Win98SE_bootdisk.iso ......... 2.63 MB
Win98SEnoram_bootdisk.iso .... 2.78 MB
WinMe_bootdisk.iso ........... 2.59 MB
WinMenoram_bootdisk.iso ...... 2.88 MB
.txt
Panasonic BIOS'S-N & Model Number Changers.txt
66
3.23 KB
Thanks given by: baner , vsandhn , fang88 , paw2000 , tshienda , ALEX®
70
(01-29-2020, 11:30 AM)Sam102 Wrote: IF you have any of these models here (CF-18, CF-19, CF-27, CF-28, CF-29, CF-30, CF-48, CF-50, CF-51, CF-72, CF-73, CF-74 , CF-M34)
Name Size MB
OS BootDisks
I have a cf31 but not he will be able to upload the biography he doesn't see information about her
how do I download the bios someone please help me
If i helped thanks and rep are appreciated  653
Thanks given by: rp1210a , tshienda
71
Hi - can decode my bios for CF-AX3?
Thank you in advance
Link is HERE
(02-02-2020, 07:28 AM)automotive_mhh Wrote: Hi - can decode my bios for CF-AX3?
Link is HERE
Read the forum rules. I'm sure there's something there about posting links.
As for decoding it. Nope, not going to take the time to do something I can delete so much faster.
.txt
Bios Passwordat original cf ax3_Cleaned.txt
15
70 bytes
Thanks given by: gabi2013 , automotive_mhh
04-10-2020, 02:16 PM
05-28-2019, 11:11 AM
Users browsing this thread: 3 Guest(s)
