Please note that, guests have limited sections to view!!!
  • 8 Vote(s) - 2.75 Average
Trasdata error 011028 on Me17.3.0
#1
Hi guys! i had to remap a 500 Abarth euro 6 with ecu ME17.3.0, i've readed it with new trasdata (ktag 6.070), all ok, then, i modified the file and then writed succesfully. Car start and runs fine, no errors. Yesterday, i had to increase a little more the turbo pressure, but when i did the id, trasdata has returned an error, E011028, not valid response from microcontroller.
Ecu is not damaged fisically and i didn't solder any cable on it, i've used the needles. Someone had the same problem?
Now i can't id, read or write Sad
Reply
Check again your pin out ...
Reply
Checked thousand times...
Reply
very time l have seen valid response from microcontroller is connections
Reply
i have the same trouble with mercedes edc17cp46 gpt. doing id with 10 attempts & then works fine.
Reply
(10-12-2017, 11:45 AM)@[email protected] Wrote: very time l have seen valid response from microcontroller is connections
Connections are ok, the firsttime, readed and writed without problems. Yesterday, nothing to do, trasdata identified the mpc, TC1724, then, when tried to identify the extflash (not present) i've got the error. Tryed 10+ times, checked connections, changed trasdata cable ecc...
Reply
Hi All!
Any body solved error [E011028] ??? HeadbangHeadbangHeadbang
Reply
Nothing Sad
Reply
Thread Author Replies Views Last Post
Hyundai ME17.9.11 Hyundai immo off kwm30 17 5,842 09-09-2018, 09:44 AM
Last Post: Alexzoz
BMW Pinout request for BMW BMSMP (ME17.2.4) with TC1793 RENNprd 7 482 08-30-2018, 10:01 AM
Last Post: dashtool2016
  Abarth ME17.3.0 BANG & HC Ecu_doctor 4 143 08-18-2018, 02:52 AM
Last Post: Edc17tricore
  ktag/trasdata Cieniu 10 878 06-08-2018, 12:35 AM
Last Post: wangtianlong
  Bosch ME17.8.5 Rotax Damos itsrealfast 1 116 05-24-2018, 09:26 AM
Last Post: skitzo
This forum is for experimental & educational purposes only. As such, it is not acceptable whatsoever to post any software that requires a license on this forum. If any member does this, she/he will be revoked her/his membership forthwith. The forum greatly appreciates the cooperation of its members on this critical issue.
Best Viewed with Chrome.
