31
Thanks Given: 67
Thanks Received: 197 (29 Posts)
250
21
05-10-2020, 03:53 AM
i have F10 535i US Version with the S840A Speed Limiter. (210kmh/130mph)
I need to flash EU Software on my ECU and renove the speed limiter. The EU Version does not have this limitation and is optimized for EU fuel.
How can i update to EU Software with icom and ista?
Thanks for your help.
157
Thanks Given: 78
Thanks Received: 253 (42 Posts)
289
53
You need to use esys, change VO and do TAL calculation accoring to the new VO, note that if you flash nbt also you will need new fsc and region change.
31
Thanks Given: 67
250
21
@mrgicm,
i must change VO from US to ECE and also change chassis type from FR73 (US market) to FR71 (ECE market), then do TAL calculation and update ECUs.
Is that correct way ?
Thanks Given: 118
Thanks Received: 70 (32 Posts)
297
34
you can not take out the limeter for 210kmh without chiptuning. Coding does not help, you can try everything, but when the engine ecu have more than 10 hours working time, you cant take out the limit.
31
Thanks Given: 67
250
21
Limiter already taken out with esys and without chip tuning.
Thanks Given: 118
297
34
ok, how you did this? I tryed many times, but nothing worked
31
Thanks Given: 67
250
21
Code Body Type from FR73 to FR71. Change VO to ECE. And then flash DME and EGS with Esys. It will replace the US Software on the ECU with ECE Software without limit.
57
Thanks Given: 314
Thanks Received: 251 (149 Posts)
1,079
150
did you fixed that or still need help?
