Thanks Given: 497
Thanks Received: 25 (19 Posts)
433
125
I have big problem , i try read via K-line and turn off dpf but can't write ://// Now i read via BDM flash maybe someone can help me and turn off DPF for this volvo V70 2005 year edc16C31 ecu?
Thank you very much for help.
v70 edc 16C31 2005year dpf on original BDM.rar
107
Thanks Given: 241
Thanks Received: 578 (305 Posts)
1,361
13
If you interest in 100% tested solution contact me private.
BR
721
Thanks Given: 143
Thanks Received: 1787 (653 Posts)
1,935
84
Yes, BDM is the best way and best dpf off solution is from bdm read
Full WinOLS/Kess/Ktag/X17/CMD
Stage 1,2,3,BT, DPF+EGR+SCR+FLAPS+TVA+CAT all off+ Crackles)
Thanks Given: 497
433
125
i never done before BDM dpf off maybe can help me ?
because I always read via obd all ecu's and done dpf off and all was ok ,but this ecu :///
126
Thanks Given: 13
Thanks Received: 301 (136 Posts)
318
To read by K line need to connect 43 pin from ECU to OBD K line ( pin 7 ).
If you need from full DPF OFF solution, you can contact me.
BR
Thanks Given: 497
433
125
o connect to 43pin I can read only this ecu :/ i do dpf off ,but can't write in to ecu :/
126
Thanks Given: 13
318
hmmm ... strange.
I never had a such problem.
BR
