  • 36 Vote(s) - 3.08 Average
VAS 5054a
[Image: gyhWV.jpg]
VAS 5054a
VAS 5054a is Bluetooth version.
VAS 5054A is a professional diagnostic tool for VW, Audi, Seat, Skoda. VAS 5054a supported functionsvas 5054a read and erase ECU fault codes, including Check Engine, ABS, SRS, transmission system, Radio, heating. ect. Turn the check engine light off. The VAS 5054A is a universal diagnostic interface for the vehicles of the Volkswagen Group and all OBD vehicle systems from other manufacturers.
The integrated Bluetooth interface connects the vehicle with a notebook, desktop PC or test system. No cables are needed for vehicle diagnostics using the VAS 5054A.
The range of the wireless Bluetooth connection is 5 to 10 meters,depending on the environment and the type of Bluetooth adapter used on the PC side. The Serial Port Profile (SPP) is used for data transfer via Bluetooth. Different Bluetooth security levels are supported.
The vehicle protocols are handled directly in the VAS 5054A.
This ensures fast response times and a reliable real-time behavior independently of the PC operating system. Every time a connection is established, the VAS 5054A software is identified with the version installed on the application PC. The VAS 5054A thus automatically adopts any new features provided after a new software version has been installed on the application PC.
The diagnostic application and the associated Diagnostic Base System are installed on the application PC. The diagnostic base system can access the VAS 5054A via Bluetooth or USB.
Access via Bluetooth: After a connection to the VAS 5054A has been set up, the Bluetooth software provides a virtual serial COM port (Bluetooth Serial Port Profile). The Diagnostic Base System uses this COM port to communicate with the VAS 5054A.You need to specify this port when you install the diagnostic application.
Access via USB: You can also connect the VAS 5054A to the application PC by using the supplied USB cable. Windows detects the VAS 5054A through Plug and Play, and automatically installs the drivers copied when you installed the diagnostic application. Setup of the VAS 5054A is then complete and the device is ready for use by the diagnostic application.
VAS 5054a language available: English/Spanish/Germany/French
The following vehicle bus systems are supported:
K line (ISO9141-2)
High-speed CAN (ISO 11898-2)
Low-speed CAN (ISO 11898-3)
J1850 (SAE J1850)
Versions:
17 - French
18 - Spanish
19 - English, Germany
.txt
VAS 5054a.txt
602
131 bytes
i need croatian software vas5054 , where download it
533
b.r
(02-21-2012, 08:38 PM)wacko70 Wrote: [Image: gyhWV.jpg]
VAS 5054a
K line (ISO9141-2)
J1850 (SAE J1850)
Versions:
17 - French
18 - Spanish
Hello
Dali that you can ask a German version and the first part of the same or use the English version?
Regards
IBI
VAS 5054a
K line (ISO9141-2)
J1850 (SAE J1850)
Versions:
17 - French
18 - Spanish
01-25-2020, 11:27 PM
12-18-2019, 08:42 PM
08-09-2019, 03:01 PM
03-25-2019, 07:18 PM
Audi
03-18-2019, 01:55 PM
