  • 20 Vote(s) - 2.9 Average
VCDS 15.7 was working but won't open anymore
This is quite bizarre, installed it about 2 months back and was working until recently, won't launch on both laptops. I have a fully chipped VAS5054a if that helps. Using 15.7 which came with the cloned tool.
Check if the correct drivers are installend.. Is the usb device shown?
If my posted helped you, don't be shy and press the thanks button.. Fing32
If you download usable and good stuff, be kind and give thanks+rep to that person Fing32
Thanks given by: bekimc
VCDS won't launch so how can i check?
You want to use vas5054 tool to 15.7.x vcds software?!
Vas5054a is for odis software not vcds
Vcds is for vagcom interface
The correct interface should say "Hex+Can" on one side, and Genuine Ross-Tech on the other.
I have vcds 15.7 with red pcb. After 2 or 3 month on that same laptop interface havn't connection with car. It seems so after some using interface ending our work. Its a programed into interface?
Solved. required vcds cable plugged to your computer. if you unplug it program won't open. than plug it open.
I have this problem too. Does anybody know what seems to be reason for this and how to solve it?
VW
Yesterday, 01:19 PM
01-21-2020, 08:13 AM
01-21-2020, 05:58 AM
01-21-2020, 02:03 AM
