  • 25 Vote(s) - 4.64 Average
VCDS 20.4.0 20.4.1 20.4.2 (ENGLISH) + Loader
163
(01-25-2021, 06:18 PM)ataitis Wrote: Hi, here is VCDS 20.4.0-20.4.1-20.4.2 (ENGLISH) + Loader, drivers, VCDS Installing Guide Video.
1.Install 01-VCDS-Release-20.4.x-Installer.exe step by steps.
2.After installed, Please don't run VCDS Release 20.4.
3.Please Close Antivirus software,Then installing 02-VCDSLoader English.exe (Note: Different Languages Software, The VCDSloader.exe Not The Same.).
4.Please disconnect internet, before using every time. Connecting cable with PC and Car OBD2 first, then Run VCDS on desktop,  Click Options--Test--Save(then can be actived software).
5.Click Options--User Interface and Identification---Set Don't check for updates.
Thanks and +REP
PM for PASS!
Thanks a lot for sharing, could you send the pass please?
(02-07-2021, 07:02 AM)ataitis Wrote:
(02-01-2021, 02:17 AM)aghelbs Wrote:
(02-01-2021, 12:55 AM)patryk1491 Wrote: Turn off anti virus. They block hook.dll
antivirus was disabled before installation, do you have any procedure i can do ??? thank you
I think you doing something wrong, still working antivirus. Try turn off antivirus different way and install again.
Thanks and +REP
PM for PASS!
Thanks given by: banicom
166
Thanks and +REP
PM for PASS!
Thanks and +REP
PM for PASS!
hi,
Pass, please
Thank in advance
Password my friend
If you have helped in any way, press "Thank you" or "Reputation"
Thanks given by: thirumal
169
(01-25-2021, 06:18 PM)ataitis Wrote: Merhaba, işte VCDS 20.4.0-20.4.1-20.4.2 (TÜRKÇE) + Yükleyici, sürücüler, VCDS Kurulum Kılavuzu Videosu.
1. 01-VCDS-Release-20.4.x-Installer.exe dosyasını adım adım yükleyin.
2.Kurulduktan sonra, lütfen VCDS Sürüm 20.4'ü çalıştırmayın.
3.Lütfen Antivirüs yazılımını kapatın, Ardından 02-VCDSLoader English.exe'yi yükleyin (Not: Farklı Dillerdeki Yazılımlar, VCDSloader.exe Aynı Değil.).
4. Lütfen her kullanımdan önce internet bağlantısını kesin. Kabloyu önce PC ve Araba OBD2 ile bağlayın, ardından VCDS'yi masaüstünde çalıştırın, Seçenekler-Test Et-Kaydet'e tıklayın (daha sonra yazılımı aktif hale getirebilirsiniz).
5.Seçenekler--Kullanıcı Arayüzü ve Tanımlama---Ayarla Güncellemeleri kontrol etme seçeneğini tıklayın.
PASS için teşekkürler ve + REP
PM!
hello pass please my frends Smile
if anybody have pass please share because this guy never answer after thanks and rep
Yesterday, 01:16 AM
05-25-2026, 03:24 PM
05-25-2026, 11:49 AM
