VW Caddy dash error after eprom changed
VW
Hi!
I have a problem with 2k0920843a, tried changing the mileage with fvdi but blocked, and the dash goes blank. Readed the eeprom value and tried another eprom content to the car. After uploaded and assembled on the ignition says the dash ERROR!
Somebody can extract the pin code from this 2 dash file?
How can I continue? Adapt keys, VIN?
Thank You very much
24c32_00.zip
File Type: .zip
Downloaded: 2 times
Golden rule!
First save everytime Backup from Original!
how you want program KEy if that cluster must have Precode KEy first ?
PIN is usseless this time
(06-13-2018, 08:51 AM)geizol Wrote: Hi!
Thank You very much
read the component security
friend i had the same problem, just disconect battery for a minut and will bee fine, it work for me.
  Scenic II 93c56 eprom language edit gsmflasch 2 84 09-20-2018, 02:20 AM
Last Post: gsmflasch
  Flash Eprom BCM AUDI Q5 DIAGMECA 2 146 09-17-2018, 10:51 PM
Last Post: DIAGMECA
  Need original eprom dump airbag megane 2 alex77vl 2 139 09-17-2018, 02:28 AM
Last Post: portal
VW med 9 eprom 95080 partsaut 2 165 09-14-2018, 05:29 AM
Last Post: partsaut
VW caddy edc16u1 immo off pls SvenBE 1 59 09-06-2018, 01:50 AM
Last Post: JBL-GG
