Hi everyone.
Have a DQ381 fitted to a MK7 Golf with P176 fault.
Originally had pressure sensor fault:
Address 02: Auto Trans (3743)
Part No SW: OGC 300 042 G
Component: GSG DQ381
Revision: 00H06V07
Coding: 0014
ASAM Dataset: EV_ TCMDQ381061 001
ROD: EV [email protected]
Labels: 0BH-927-711. clb
HW: OGC 927 711 G
H06 1424
1 Fault Found:
10668 Position Sensor for Clutch 2
P1736 00 [00101000] - Electrical Malfunction
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 184192 km
Date: 2024.04.29
Time: 23:59:13
Engine RPM: 873.00 /min
Vehicle speed: 0 km/h
Coolant temperature: 92 °C
Clutch: primary stat: Neutral
Unit has had new pressure sensors fitted. Above code no longer present.
Selects all forward gears fine but then plays up when coming to stop and no reverse gear intermittently.
Now has P176F code
10748 - Clutch 2 Closes Unintentionally
P176F 00 [00101110] - -
Intermittent Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 185686 km
Date: 2024.06.04
Time: 16:28:34
Engine RPM: 847.00 /min
Coolant temperature: 62 °C
Clutch: primary stat: Creeping selected gear: GANG 2
Driving position: d
Engine torque: - 8 Nm
Control Module temperature: 50 °C
Accelerator pedal position: 14.9%
DTC memory status: 92
Basic settings been carried out but fails.
Can anyone assist
Many thanks
Revision: 00H06V07
Coding: 0014
HW: OGC 927 711 G
H06 1424
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 184192 km
Date: 2024.04.29
Time: 23:59:13
Now has P176F code
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 185686 km
Date: 2024.06.04
Time: 16:28:34
Driving position: d
Can anyone assist
Many thanks
