Kaya007
Location OfflineJunior Member
0
Thanks Given: 33
Thanks Received: 4 (3 Posts)
79
30
07-16-2020, 06:51 PM
(This post was last modified: 07-16-2020, 08:09 PM by Kaya007.)
I have change CCM and ELV all works fine but the central locking system NOT work only yellow blinker blinks. I have no errors in diagnosis.
The switch on the driver door also it does not work. is it a coding problem?
43
Thanks Given: 217
Thanks Received: 336 (156 Posts)
597
141
A clue to what car this is on would be helpful
If i've helped don't forget the magic buttons, thanks + rep
43
Thanks Given: 217
597
141
have you reprogrammed the remotes back into it.
Channel 001: Remote Control Matching
Start Matching new/additional Remote Controls with entering 1, then Test and Save the New Value.
Press the Unlock button on each Remote Control you want to add, the Blinkers will light up to confirm the Adaptation Process of each Remote Control.
Kaya007
0
Thanks Given: 33
79
30
It was a coding problem... I solved the problem
0
Thanks Given: 33
Thanks Received: 3 (1 Posts)
20
Hello. Exactly the same problem. Passat b6 2006 model.
Any help?
