  • 1 Vote(s) - 5 Average
VW Passat B6 TRW Airbag 3C0909605M crash
Passat 6 Airbag Module TRW VW8 3C0909605M 391125 10 H030 S2522. Both front airbags and both belt tensioners crashed at an accident. Other airbags and tensioners are installed but can not clear the DTC from the airbag module. I tried with VCDS but I still have 3 DTCs: 00588 - airbag igniter, Driver side (N95), 00654 - Seat Belt Tensioner , Driver Side, 00003 - Control Module Defective. I've tried a few clean files but no one is ok, I have more DTCs. I tried to put another Airbag Module with the same number but I'm not able to do the coding module with the VCDS. If someone has a tested solution, please help. No free help is required.
Thanks in advance.
VW Passat 6 TRW 3C0909605 M crasch.rar
File Type: .rar
Downloaded: 10 times
Cleared.
Regards
VW Passat 6 TRW 3C0909605 M crasch_cleared.rar
File Type: .rar
Downloaded: 6 times
Thanks given by: milanko
#3
Thank you for the file but it is not ok, I have DTC 00003-Control Module 014 Defective MIL ON.
If you have a solution, please help.
Know someone if it is possible to do crash clear on the Passat 6 TRW airbag module. I've tried 10 versions but I always have DTC 00003 Control Module 014 Defective MIL ON.
Thanks in advance.
Thanks given by: reproteq
#5
(07-14-2018, 12:22 AM)milanko Wrote: Know someone if it is possible to do crash clear on the Passat 6 TRW airbag module. I've tried 10 versions but I always have DTC 00003 Control Module 014 Defective MIL ON.
Thanks in advance.
hi mate
same problem 3C0909605J
you solved?
wat file ?
thanks alot
Thanks in advance.
hi mate
you solved?
wat file ?
thanks alot
No, tried 20 files always the same problem.
ok thanks
SOLVED ! Thanks to all.
  OPEL VECTRA C - TRW 13 129 843 CL EEPROM Location forumtmp 10 1,784 Yesterday, 10:54 PM
Last Post: lampinen
Renult airbag megane 3 crash technoart 1 51 Yesterday, 04:04 PM
Last Post: Andrnet
Hyundai Hyundai ix35 airbag 95910-2y300 crash Lichir.technique.gtfs 3 76 10-14-2018, 10:54 PM
Last Post: Lichir.technique.gtfs
Hyundai Hyundai ix35 airbag 95910-2y300 crash Lichir.technique.gtfs 0 35 10-14-2018, 01:29 PM
VW hello wosvagen golf-7 airbag crash claer please.. hasankgrc 0 54 10-11-2018, 07:43 PM
Last Post: hasankgrc
