  • 125 Vote(s) - 3.22 Average
VW RNS315 map update
163
Can not overwrite CID
Where did I go wrong ?
SD card - samsung evo+ 32gb
HP pavilion DV6700 32bit instal Linux
[email protected] ~/Plocha/VW $ sudo su
[sudo] heslo pre používateľa evdo:
evdo-HP VW # ll
celkom 604
drwxr-xr-x 2 evdo evdo 4096 okt 6 16:53 ./
drwxr-xr-x 3 evdo evdo 4096 nov 9 17:20 ../
-rw-r--r-- 1 evdo evdo 5050 okt 21 12:45 how_to_RNS315.txt
-rwxrwxrwx 1 evdo evdo 240248 sep 16 00:00 mmc32*
-rw-r--r-- 1 evdo evdo 357679 sep 9 20:46 mmc64
evdo-HP VW # chmod 777 mmc32
evdo-HP VW # ll
celkom 604
evdo-HP VW # df
Súborový systém 1K-bloky Použ Dostupné Pou% Pripojený na
udev 1011680 0 1011680 0% /dev
tmpfs 206128 6556 199572 4% /run
/dev/sda6 7557288 6053296 1097056 85% /
tmpfs 1030636 208 1030428 1% /dev/shm
tmpfs 5120 12 5108 1% /run/lock
tmpfs 1030636 0 1030636 0% /sys/fs/cgroup
/dev/sda5 463844 57761 377616 14% /boot
/dev/sda8 8011960 2750228 4831704 37% /home
cgmfs 100 0 100 0% /run/cgmanager/fs
tmpfs 206128 36 206092 1% /run/user/1000
/dev/mmcblk0p1 31263744 2916608 28347136 10% /media/evdo/KARTA
evdo-HP VW # cat /sys/block/mmcblk0/device/cid
1b534d3030303030105c4d5772010a00
evdo-HP VW # sudo ./mmc32 prog_cid /dev/mmcblk0 5d53424c32424d31013917ca53010400Writing new CID.
ioctl: Invalid or incomplete multibyte or wide character
evdo-HP VW #
THX
(11-09-2016, 09:53 PM)jokir Wrote: [Image: 9]
Writing new CID.
ioctl:Invalid or incomplete multibyte or wide character
THX
Maybe your SD-Card reader is USB-Version (even if internal)
Try different PC.
I tried another PC, but only Linux Live (from USB key) , without success
Linux must be installed ?
No need to install. Try with Ubuntu. That's what I used. But I get message that SD Card is not geniuine Samsung
PC ASUS X550C 64bit Linux live
[email protected]:~/Desktop/VW$ sudo su
[email protected]:/home/ubuntu/Desktop/VW# ll
total 596
drwxrwxr-x 2 ubuntu ubuntu 100 Nov 10 15:04 ./
drwxr-xr-x 3 ubuntu ubuntu 120 Nov 10 15:03 ../
-rw-r--r-- 1 ubuntu ubuntu 5050 Oct 21 12:45 how_to_RNS315.txt
-rw-r--r-- 1 ubuntu ubuntu 240248 Sep 16 00:00 mmc32
-rwxrwxrwx 1 ubuntu ubuntu 357679 Sep 9 20:46 mmc64*
[email protected]:/home/ubuntu/Desktop/VW# chmod 777 mmc64
total 596
[email protected]:/home/ubuntu/Desktop/VW# df
Filesystem 1K-blocks Used Available Use% Mounted on
udev 1950292 0 1950292 0% /dev
tmpfs 392992 6308 386684 2% /run
/dev/sdb1 3805184 1495584 2309600 40% /cdrom
/dev/loop0 1399936 1399936 0 100% /rofs
/cow 1964940 57796 1907144 3% /
tmpfs 1964940 140 1964800 1% /dev/shm
tmpfs 5120 4 5116 1% /run/lock
tmpfs 1964940 0 1964940 0% /sys/fs/cgroup
tmpfs 1964940 4 1964936 1% /tmp
tmpfs 392992 72 392920 1% /run/user/999
/dev/mmcblk0p1 31263744 2916608 28347136 10% /media/ubuntu/KARTA
[email protected]:/home/ubuntu/Desktop/VW# cat /sys/block/mmcblk0/device/cid
1b534d3030303030105c4d5772010a01
[email protected]:/home/ubuntu/Desktop/VW# sudo ./mmc64 prog_cid /dev/mmcblk0 5d53424c32424d31013917ca53010400
Writing new CID.
ioctl: Invalid argument
[email protected]:~/Desktop/VW$ sudo ./mmc64 prog_cid /dev/mmcblk0 5d53424c32424d31013917ca53010400
ioctl: Connection timed out
Failed to enter vendor mode. Genuine Samsung Evo Plus?
It's genuine 32gb Samsung Evo Plus SD card?
microSD card is purchased in the store 17 euro
Samsung EVO + 32gb - red color
MB-MC32D
MBMCBGVEDFCW-PKPANA24AW640
Made in Philippines
Writing new CID.
THX
Try different PC.
I also had the same problem and on another laptop worked as a charm, the sd card must be shown as mmcblk"xy" also it does not matter if ubuntu is installed or runed from usb key or dvd booted.
I tried to 4 pc,but CID'm not overwrite
I think my SD card is fake
06-23-2019, 02:27 AM
Renult
06-08-2019, 02:43 PM
Audi
06-06-2019, 02:45 PM
Chrysler
06-01-2019, 02:11 PM
