  • 19 Vote(s) - 2.74 Average
Variant Coding ME2.8 W203
Hi @all!
I have a problem with the variant coding from the ECU ME2.8 (S203 C320) in developer mode. Sometimes when I read the codings it works and sometimes not. So when it doesn´t work the DAS says "... at least one coding is invalid..." and for every coding I can only see "---".
Yesterday I had that issue during the engine was running. After i stopped the engine i could read the codings an change them (e.g. KLD1 to KLD2).
Today it doesn´t work again. Doesn´matter if the engine is running or not.
Anybody knows the problem?
Regards,
Ignacio
(08-31-2016, 05:51 PM)Mr.Ignacio Wrote: Hi @all!
Regards,
Ignacio
Unplug your OBD connector wait 2 seconds, plug it back and read again. It should work. I got this advice from a Senior Mercedes guy Smile
Thanks given by: laco210 , malguy , Mr.Ignacio
Thanks mate! I´ll try that later today and report.
You don't must unpluged OBD, just log out with ecu switch off/on ezs, and must work.
