Vauxhall Corsa 2013 ABS pump fault - no fluid to 1 wheel
Hi Everyone
Does anyone know the solution how to fix 2013 Vauxhall Corsa ABS pump, the fault is no fluid to front passenger wheel. Apparently it's a very common issue.
Part numbers from the unit are:
0265232288
13282282
0265800796
Try to replace the metal body part with the motor on. Looks like a valve inside the abs alluminium block is stucked. Good luck
Opel
06-12-2026, 06:31 PM
06-12-2026, 06:27 PM
