  • 64 Vote(s) - 3.06 Average
Vediamo v05.00.05 (plenty questions)
28
What You want to do by Flashstation?!? If You mean a flashing an ecus's - a "flash" tab in Ecoute is for it. About the short test - You have somewhere kurztest.ini (probably VediamoData folder) file responsible for it (You have to edit it for a correct working).
Regards!
____________________________________________
SCN, Comand navigation Pins (update, antitheft), manual codings, retrofits, NOX/SCR off, ILS, LED's etc.
skype: merc.diag
Just press THANKS and + buttons if I helped You...
Thanks given by: Yudi , Marcos
29
I'm getting same error with CRD3, any suggestions?
(08-27-2014, 03:43 AM)karakan08 Wrote: I'm getting same error with CRD3, any suggestions?
The problem is the CBF files which your using,try to use factory database
Hello all experienced Vediamo users,
I am seting up for a friend a DAS Xentry System for diagnosis.
This already worked.
But he asked me vor example:
Which Program is able to make it possible to change the ECU of a 7G Transmission? (In Xentry a online change with a code has to be performed)
He wants to do it offline.
After a detailed search I found some informations that Vediamo is able to do this kind of offline programming.
Now my questions:
Should be Vediamo V5 installed at a empty XP System or should it be installed into a system where Xentry with drivers is already installed?
What do I have to change in the system configuration to use it with a SD connect (Compact4)? or is everything set by the installation of vediamo?
Which CBF files should be used with Vediamo in Xentry I found already the Xentry/DAS CBF files but in one post I read that they are different available for vediamo which give more possibilities in porgramming the ECUs.
Which additional possibilies have these "special" CBF files?
Does anybody has some kind of FAQ with explanations for Vediamo which he/she may share?
I hope somebody will be able to give useful help with my questions.
Best regards
Jake
My Youtube channel
https://www.youtube.com/c/JWAutomotive
Check it out and subscribe ;-)
Have a look here and see if this helps..
http://mhhauto.com/Thread-Coding-722-9?p...#pid302230
Thanks given by: Yudi , amr_200 , Jake5555 , webmaster , avandgarde , zdzich
33
(08-29-2014, 08:20 PM)Jake5555 Wrote: Hello all experienced Vediamo users,
Now my questions:
Best regards
Jake
Search for vediamo thread, i think all of your questions will be answered ...
simply
1.vediamo can be installed in any xp pc,as long as it has space no matter there is xentry or not
2.you need to select Part D i think and you will see the serial no of your mux
3.you need to use factory CBF ,those cbf from xentry folder will do nothing to your coding
Thanks given by: Jake5555 , r66r66 , alex_ng
34
Now my questions:
Best regards
Jake
simply
Hello ivannzowa,
thank you very much for your answer. This helps me already alot.
One further question:
Are you able to share the factory CBF Files with me?
Best regards
Jake
My Youtube channel
why is vediamo so popular and desired here on the forum when it is useless without the cbf factory database? I haven't used it before, just curious to know.
(08-30-2014, 04:57 PM)Wilbur Wrote: why is vediamo so popular and desired here on the forum when it is useless without the cbf factory database? I haven't used it before, just curious to know.
Hi..............
Simply m8..........
Like Aut*d*t*........ Business.......... CashCashCashCashCash
Regarts.......... Beer
