  • 27 Vote(s) - 3.11 Average
Vito 639 safe mode. B60 component. help please
Hello mhhauto members! I have a problem with a vito w639. The van is suffering from loss of power at low revs and frequently goes into safe mode. The fault code is always this one 2641-008 component b60 (exhaust back pressure sensor) does not function properly plausability. I delete it and whenever i start the van it comes out again. I have changed the back pressure sensor and egr as well. Since i have very low boost at lower revs and with this fault code, i believe the porblem lies with the turbo . Any suggestions please?
1. DPF is full
2. intake manifold defective
3. turbocharger defective
Frequently one is turbo with defective variable nozzle vane(geometry)
Disassembling exhaust gas tube with FAP/DPF would not give any effect because sensors withought filter anyway will switch engine to emergency mode>> thatll give same dtc as your fap/dpf is broken through
MB cluster algo's in stock / j2534 ecu/tcu/ism resetter
Stand with Ukraine
Thanks edsmela. I will start by removing dpf and see if it is physically blocked for starters and then move to turbo. I will post what happened for future reference. The van has about 350.000 km on it so everypart you talked about and more are suspects.
