M112 W220 Missfire
(06-07-2026, 09:05 PM)Anturage Wrote: Compare with cylinders working normally. You should have at least Kl.15 up
On what pin should i have KL15?
Compare to working cylinder or look at wiring diagram in WIS 07 group
  • SW Seed\key VGS\MED\IC virgin\hard coding Carplay HU5s1 HU5es2 any fw
  • HW Genuine XentryConnect-SDConnect-eCom sale\repair\parts\setu
(06-07-2026, 09:17 PM)Anturage Wrote: Compare to working cylinder or look at wiring diagram in WIS 07 group
Did some testing and measuring and KL15 seems to be missing. took some jumpercables to try and its still running bad after but could be my ignition coils and or also spark plugs being bad
Open engine wiring harness. Find where is the open circuit. Repair it and inspect other wires in the harness. They may be damaged as well. Wire isolation cracked for example. Continue with engine diagnostic only after engine wiring harness will be inspected and fixed and insulated with proper materials. Or replace complete engine wiring harness.
https://mhhauto.com/Thread-StarFinder-we...fline-2023
All of your wiring diagrams are here..
05-21-2026, 12:05 AM
04-15-2026, 08:04 PM
04-15-2026, 02:58 PM
