383
Thanks Given: 922
Thanks Received: 1396 (515 Posts)
1,230
169
07-26-2016, 12:50 AM
Hello friends,
When I driving for a while with 120km/h then come esp light and the cars is in limp mode. I reading and the fault codes in ESP are:
1) 51A5-IMPLAUSIBLE ACCELERATOR PEDAL MESSAGE RECEIVE
2) 6808 esp-regulation
3) 6800 abs-regulation
I changed accelerator pedal with new, but still same.
Can someone help me?
858
Thanks Given: 1736
Thanks Received: 1864 (417 Posts)
789
72
On engine control unit you have errors with gas pedal? Ist euro 5 engine OM651??
If I helped do not forget to press thanks and reputation button
383
Thanks Given: 922
1,230
169
Vito W639 115CDI 646.982 150hp
In engine control unit I have this faults:
1)1234-002 Accelerator pedal position
2) 2062-002 B40 oil level sensor
3) 2062-004 B40 oil level sensor
4) 2062-008 B40 oil level sensor
5) 2014-008 B40 oil level sensor
6) 2040-001 B40 oil level sensor
7) 2040-008 B40 oil level sensor
8) 2041-008 B40 oil level sensor
480
Thanks Given: 294
Thanks Received: 3152 (1823 Posts)
3,432
77
check contact on ecu and wire motorroom
383
Thanks Given: 922
1,230
169
Checked. The wires are good and the ecu is very clear
383
Thanks Given: 922
1,230
169
This is the quick test from the last time
