  • 85 Vote(s) - 2.99 Average
Vivid Workshop DATA ATI v.10.2 EASY CRACK!!
28
does this vivid expire? I got message to say it will expire in 13 days from now!
Correct- I have been Installing Euro Software for 17 years and Im no dummy, and everyone here is correct - following SIMPLE instructions here and the programme works for just one day and the next day its ZERO days and expired. I can not possibly see how this programme goes for 400 days let alone 2 days, so somebody has got something wrong, and its not all these people here doing anything wrong. Very dissapointing after downloading 3gb from work servers and it doesnt work.
(08-22-2011, 10:14 AM)tonydj Wrote: Correct- I have been Installing Euro Software for 17 years and Im no dummy, and everyone here is correct - following SIMPLE instructions here and the programme works for just one day and the next day its ZERO days and expired. I can not possibly see how this programme goes for 400 days let alone 2 days, so somebody has got something wrong, and its not all these people here doing anything wrong. Very dissapointing after downloading 3gb from work servers and it doesnt work.
That doesn't happen with mine. been working for few months but just now I have 11 days left unless I wound back my time and date settings
hi everyone, im having the same problem like vcidont, i try to patch vividworkshop qith any crack but nothing, first i try with the long crack using vivid_reg and crypkey with this i have 381 days but a screen appears saying that 8 days left to expire and the program will not run anymore, then i try with this crack and the same think with the difference os 400 days, as vcidont say unless you turnback date settings like 28-jun-2011 what could be the problem
Now there is other problem, time locked soft, soft is locked after september 3.
but never mind, i made new trick, read the txt file inside zip
Best regards!
.zip
Vivid Easy Crack.zip
1,475
47.57 KB
33
Hello, i try to run Vivid but when i run i see only start screen without continue. Program is in sleep. Where is the problem? I try to update java then run the program but without success. Please help me. Where is the problem. System is Windows Xp Professional with Service pack 3.
(08-28-2011, 09:56 PM)oemotorsport Wrote: Hello, i try to run Vivid but when i run i see only start screen without continue. Program is in sleep. Where is the problem? I try to update java then run the program but without success. Please help me. Where is the problem. System is Windows Xp Professional with Service pack 3.
Witch EXACTLY Language you using on your Control Panel > Regional Settings????? 39
I use Bulgarian language.
(08-29-2011, 12:13 AM)oemotorsport Wrote: I use Bulgarian language.
Vivid DID NOT Supporting Bulgarian Language m8! Smile
The Supporting Languages for Version 10.1 or 10.2 (MOD Version) in sort they are those:
DAN - DE - GR - ENG - ES - SUO - FR - ITA - NL - NOR - PT - SE
So... IF you will change in your Regional Settings from Bulgarian to ---> English
for example, then you will been = Fing32
NO any Freezing or anything else as you had! Wink
Best Regards! Cheer2
Thanks given by: webmaster
AA+MHH
05-19-2020, 04:57 PM
05-12-2020, 08:04 PM
04-14-2020, 06:39 PM
04-09-2020, 10:32 AM
Users browsing this thread: 3 Guest(s)
