To obtain your inv. code (registration code) kindly contact [email protected] Please note that, guests have limited sections to view
Volvo D13 DPF Outlet Temp LOW
#1
Any ideas why DPF outlet temp is low? 2009 volvo...  7th Injector pressure is 64PSI, truck runs regen for 30 minutes and it stops.  It does not lower soot at all.  Thing is stuck at 144%.  Changed DPF Filter, same thing, stuck at 144% (I even reset Soot via VCADS), still shows 144.  It doesnt go up or down.  Driver had piece of tape over the DPF lamp, I guess it was on for some time, he would do parked regen, truck will run, but message will stay on, that regen is neede.....this one is odd..
Thanks in advance
Reply
What temps an all three sensors do you got during regen? How fast DOC and DPF inlet temps raise? Have you replaced DPF only or DOC also? Have you checked exhaust leaks? Have you replaced 7th injector? What ACM active codes do you have?
Reply
Thanks given by: quality truck
Thread Author Replies Views Last Post
  Volvo loader dpf deletes needed catfan 5 350 10-09-2018, 03:13 AM
Last Post: Simonnismo13
Volvo new volvo d13 with the obd plugg victornsac 13 3,725 10-06-2018, 05:26 PM
Last Post: itko75
Volvo Volvo L180G DPF OFF? peha 5 219 10-05-2018, 04:18 AM
Last Post: Eemre44
  2012 Volvo VNL D13 Help needed! VirusX 12 304 10-02-2018, 01:47 AM
Last Post: VirusX
  M11 Celect Plus Fan on/off temp? CDNFirewerks 5 120 10-01-2018, 09:23 PM
Last Post: CDNFirewerks
This forum is for experimental & educational purposes only. As such, it is not acceptable whatsoever to post any software that requires a license on this forum. If any member does this, she/he will be revoked her/his membership forthwith. The forum greatly appreciates the cooperation of its members on this critical issue.
Best Viewed with Chrome.
