  • 9 Vote(s) - 2.89 Average
Volvo ECU pinout
I'm going to make bech harness for my Volvo ECU.
I'm looking wiring diagram for this ECU.
This is D13 Model VN and it will work for ur ecm.
Performance tuning EGR, DPF and DEF * Original files available.
Volvo , Mack , Detroit , Cummins , Paccar , Hino , Isuzu , MaxxForce.. Etc
Thanks given by: fang88
From a Mack Manual but would assume Ecm pinout would be the same.
21042371 is ems 2.2 you can use the schematic of any truck volvo/mack/renault
Thanks given by: ejh1 , pies , fang88
(05-31-2018, 10:59 PM)Studioba Wrote: This is D13 Model VN and it will work for ur ecm.
I wonder if each plug /A and B/ has power and ground wires ?
I dont understand why 2 wiring diagram shows same pin numbers for PWR and ground?
Ea 57 gnd and eb 57 pwr .. I did the harness with just power to pinB .57 60 ..pinB gnd 58 59 61
Pins are in 2 different plugs, one in A, one in B
It needs only power at B Plug. Just do same as it shows on image
07-10-2019, 09:56 PM
06-05-2019, 01:36 PM
05-14-2019, 03:12 PM
