  • 16 Vote(s) - 2.44 Average
Volvo Prosis Error Fix
you got this:
not connect to net.tcp://localhost:7311/UpTime/UpTimeApplication/ProsisService/. The connection attempt lasted for a time span of 00:00:01. TCP error code 10061: No connection could be made because the target machine actively refused it 127.0.0.1:7311.
i solve this error!
1. desable antivirus and firewall
2. go in service
3. find uptimeservice and oracle XE
4. go in proprieties and put manual and apply
5. restart your computer
6. go in firewall avanced security
7. add new rule in inbound rule and outbound rule
8. select PORT----TCP----specific local port add: 7311
9. Allow connection
10. same process whit outbound rule
11. go in service
12. start uptimeservice and oracle XE
13. open Prosis
14. go in service
15. put uptimeservice and oracle XE in proprieties Automatic (Delayed start)
....is fixed for me!!
good work, I installed prosis, then the pc not connect network, not install any software, and make a clone, if prosis don't work ,recover it.
i like volvo ecu repare
i can help you by teamvwere
Thanks given by: mcartier
it is really work well ???
yes i tested
(09-19-2017, 09:29 PM)kashaki Wrote: yes i tested
can you make a TV video for fix ?
thanks so much
(07-31-2017, 08:34 PM)kashaki Wrote: you got this:
i solve this error!
2. go in service
9. Allow connection
11. go in service
13. open Prosis
14. go in service
hello, Friends
Thank you for good information
help me
oracle XE has three service lists
(1) oracleXEClrAgent
(2) oracleXETNSListener
(3) oracleServiceXE
What attributes of a list do you change?
thank youbowbowbowbow
regards
ime-actia
Thanks given by: EhabYoussrey , moftah
did not help me
ancient anguish
be polite  Handshake
let's reputation  Fing32
Yesterday, 03:13 AM
06-09-2021, 04:24 PM
06-09-2021, 12:53 AM
Volvo
06-08-2021, 06:46 PM
